Falcon Jr., Can the print head make the printer to loose colors
creative
Hi all,
Can the printhead make the printer to loose either of the colors C-M-Y
I touhg it may had a bad damper, I;'d replace them all but I can get the yellow to "prime" "charge" i can suck ink out but it goes back to the cartridge.
any help?
Compilla
-Take cover off printer and check to see if the ink lines have kink / hole or leak.
-Inspect the right print head manifold, it is possible that you crack it while you replace the dampers.
-Check the condition of the O rings as well.
Just my 3 cents... lol
creative
I'd re-inpected everything and to my surprise the new damper had a leak, I'd called the supplier, they are sending a replacement.
thank you.
