I need to know what purpose a certain part is for and where I can obtain a replacement (if needed).
The part the 2 heads sit in (in my machine is silver metal) - this has 2 clicking/sliding dials up front, and 1 on the right side, my issue is that the dial on the right side has been broken (a black plastic tab that would normally dial through the clicker). What is this for and could this have caused my right head to not fire at all (but left printed fine - heads were replaced, capping, pump, mother board was sent out for repair (there was nothing wrong) - replaced dampers, flushed all lines from cartridge - to waste bottle, replaced head ribbons, tried different inks, ran cleaning and ink fills, syringe pull from the dampers - basically a new printer at this point and still unable to print to my dismay (out of either head), then I found this broken part)?
To be honest I do not know what the 2 front dials are for either and being a small business owner, simply do not have the bucks to bring in a proper tech - so have been doing repairs myself (this forum has been great for research) but after 4+ months being down starting to wonder if I should throw in the towel.
Also I am on my 3rd set of heads, they keep drying out on me in between repair (as well, all dampers I have to keep replacing) - I am hoping to not have to order a 4th set, any tips on unclogging them (I have tried soaking them in the cleaning fluid (out of cleaning cartridges) but on all 6 heads there seems to be 1 or 2 colors not flowing from each (I use eco-solvent inks).
