elsignshop
I would like to know what this means?
Please post a nozzle test print from the printers interface.
well when i check if the head nozzle are clogged i get a syringe with little bit of alcohol and put the syringe in each hole where the dampers connects to the heads. then i push alcohol into the heads to check if all the nozzles are clean or clogged. but im loading a nozzle check right now. But now only black and blue come out no magenta or yellow coming out.
