Falcon JR printing BK with a CMY mix?
creative
:help: Hi All;
Our falcon jr started to print color black with a mix of CMY, I had seen the settings option to use CMY + BK then you select YES or NO, but I can remember where in the hidden menu is...
does anyone knows where in the hidden menu can we find that?
Regards.:thankyou:
creative
Thank you, I'd found the setting.
As follow: Start printer as normal, depress menu then menu again until you see utility, then menu again until you see CMY=BK YES or NO select NO and you're set.
regards.
