haveing a problem with ink fading on a 62 falcon outdoor
i have been fighting with this for 2 weeks now
have check for air leaks replaced print heads o-rings dampers ect
pulled a vac check on the ink lines from damper lines to the cartage needles
it act like ink starvation but i changed from orcal 3651 to avery 1050 ez
and it seems to print great
so i figured i had bad media i changed to a 2nd new roll fresh from fellers
and have the same problem also tried to adjust heat settings nothing seem to work
also trying to find a mutoh service teck in nashville tn area
thanx for any help you can provide
gary
gary
