Faulty HeadBoard?
tigerwoodz
View As Web Page Hi guys
I am in desperate need.
I have had the original head board for ten years. Fuses have been replaced numerous times. The last time the cyan/black fuse blew I changed the transistor and the fuse but it still didnt work. Y/M, Lc/Lm printed fine.
I replaced the head board along with all the head cables. Now the test print for magenta is only half a head and it leaves a blurry line next to the purge sponge.
When printing yellow overspray from star to finish.
I have contacted the company who supplied the board. They are unsure that it is theboard that is faulty, after reinstalling the old one, with M/Y working fine I can only see it being the head board.
Apologies for the essay, I would be very grateful for any help or advise
Many Thanks Stephen
DRW
What machine do you have? In the first pic, the magenta in B may indicate a clogged damper. I've had that happen before on a vp-540. Do you have the correct cables in their correct slots?
tigerwoodz
The machine is an sj740 - it is approx 10/11 years old, I am currently in the process of refurbishing it
When I reinstalled the old headboard the magenta worked fine
I have changed all manifolds, dampers, caps, head cables, carriage board, head board cables.
The new board has a test date 26.12.12, is it likely to be faulty?
