We are running some .015 clear rigid vinyl sheets (25"x52") second surface with a white flood and are getting head strikes due to the heat from the lamps. We are using the clear sheet profile with the vacuum on high and the lamps on low. Anybody have any suggestions on how to prevent this? We also just got done running a large job on .020 styrene and were running into similar situations. We resolved this issue by aligning the image to the back of the sheet which allowed for 5" of extra material (leading edge) on the front.
Do any of you have any tips/tricks for running thin material? Especially materials that react to the heat from the lamps.
Thanks in advance!
Thanks in advance!
