Need Help FB500 carriage noise
Jacob
Well, what do you wanna change? The aluminum trolley with the 5 small wheels on it?
yeah the bottom trolley wheel exploded. What little i can find on it you have to dismantle the entire head and re calibrate everything. I would love to hear it isnt that bad.
czbhu
It isn't that bad. Does it help?! :)
Anyway, do you have the new piece of that aluminum? If you do it takes about 2-3 hours to change. You can do it by yourself but I suggest you to have someone to help you. Just for like holding the cart or hold pieces together until you are screwing.
Turnergraphics
It's not so bad . Remove the bolts on the back of the carriage that hold the belt in place. Pop one side of the belt loose from the slot that it fits in. Lift the carriage straight up and rest it on a soft towel. Change the part you need and put it all back together.
Sent from my SM-G973U using Tapatalk
Turnergraphics
You'll need a helper to guide the encoder strip into the slot when you put the carriage back in place. Go easy or you could bend the encoder strip. The only calibrations you need afterward are auto bidi and auto head to head.
Jacob
Update. Got the parts did the install today. Took about 3 hrs with a buddies help. Relly simple and straight forward. Printer is up and running after a few diag checks. Thanks for the answers, this saved me a boat load of money.
czbhu
Keep that bad part and show it to a local cnc lathe specialist and have him reproduce by the old one. It would save you money too if next time one of the rollers goes bad. On the original part they are pressed on so they cannot be changed.
Great Signs
I had the same issue and in my case a new trolley replacement was the solution. The bearings in the old trolley were well worn and causing my issue. I still have the old trolley and if I detect any issues with the new trolley, I will try to swap the bearing is out with the help of a do it all friend
Great Signs
Can this be replaced on my own. they want 6000USD to replace it for the labor
It cost me around $1600 for the part and the labour... 6K is a price gouge... if they can change it so can you with the instructions that come with the part
