FB700 - reading a chip
danno
Is it possible to read a chip and not install the ink cartridge? In this case, the operator,yes me, had a brain malfunction and didn't record the amount of white ink left when I swapped back to 6 colour. :banghead:
danno
issue resolved. I found the weight of a new carton of ink, then weighed mine. The issue with plugging my chip in to give a reading was that it was the white chip. I was set up for 6 colour at the time and didn't want to start the changeover process just to see how much ink was in the carton. Next time I will keep better notes.
Turnergraphics
new ink coms with a new chip . My specific problem was that the chip said I was out of ink . But I wasn't out of ink. So HP sent me another chip so that I would be able to use the rest of the ink. The chip keeps track of how much ink travels from the ink station (each color station). You're right that a chip 'quits' if it thinks the ink is out. But if it quits to soon pop in the chip that has some room left on it. HP can send you a chip with room left on it.
Turnergraphics
great!.
turner
Davo
Just run the ink past 0, it has no effect ont he workings of the printer. I check the actual ink left in the bag before replacing a carton and profiler chip.
