FC 8000 Only Cutting Numbers
Graphic Worx
Graphic Worx
Using Onxy 10 with the Graphtec I can see and connect to plotter but when I send a cut file it just starts cutting little numbers anyone have any ideas?
bob
Change the plotter to GPGL from HPGL. Or vice versa, I can never remember which software uses which language. Whichever one it's set to, change it to the other.
Or better yet, switch it to auto-configure to the language that is being used by the application that is driving the plotter. This is done from the Menu button on the Graphtec control panel (> I/F > Command > Auto > Save).
Esdale
I have found that the Auto setting works the best when cutting from ONYX 10 with the Graphtec plotter
Graphic Worx
Graphic Worx
now its cutting everything 90 degrees from what it shows on screen. we have a mimaki cutter and what you see on screen is what it cuts
