FC vs CE series Graphtec Plotters
Discussion in 'Graphtec' started by kalvix, Dec 29, 2005.
  1. kalvix
    kalvix Member
    318
    1
    18
    Apr 17, 2005
    washington dc
    graphtec ce3000 48 vs. fc7000 series. Is it worth the extra $1-2k for the FC series? has anyone had both?
  2. Pro Image
    Pro Image Major Contributor
    4,550
    Nov 28, 2005
    I have a CE1000-60 and its is a real workhorse no problems, over 7 years old. You can't go wrong with either choice....................
  3. kalvix
    kalvix Member
    318
    1
    18
    Apr 17, 2005
    washington dc
    how are registrations and aligning printed material? I've read about the AIMS on the fc but i'm not convinced it will be a real time saver. do you do much aligning stickers and such with your CE?
  4. Derf
    Derf Very Active Member
    I have a new CE-3000 now and an old FC2100-60. I can tell you the old FC2100-60 is a better machine than the new CE... I wish I would have gotten the new FC instead and will probably get one soon.
    The CE is a good machine However the FC line is worth the extra coin.
  5. Pro Image
    4,550
    Nov 28, 2005
    No I do not have a large format digital printer.....just a Fargo 310s that I use to put Real Estate agents photos on magnetics................
  6. ADM
    ADM Member
    30
    Why is it worth the extra $$$. What does it do that merits the extra cash? I appreciate your feedback as I am looking to get a new cutter and I am leaning towards the ce-3000
  7. wildside
    wildside Very Active Member
    1,469
    20
    38
    Aug 28, 2005
    Kansas
    we have used the ce in the past and had decent results, touchy sometimes.
    we recently purchased a FC5100-150, it is actually a discontinued model, but compareable to the new FC7000, top notch machine, in my opinion the fc's are geared toward the "sign professional", the ce's are geared toward the "give me something that is cheap and will work in my basement crowd"
  8. mark in tx
    mark in tx Very Active Member
    2,081
    Oct 25, 2005
    Harker Heights, Texas
    I want another FC series. Just a fantastic cutter all around.
  9. ScottyDoo
    ScottyDoo Member
    297
    Jan 2, 2006
    We just had our FC7000-160 installed today...just doing some print/cut tests.
  10. Jackpine
    Jackpine Major Contributor
    I use a ce3000 to cut vinyl and to cut contour cut print from my Mutoh. Works good.
