FC5100 Cutting off in CM2
signnerd
Hello, and thanks in advance for any help you can provide!
I've got an old FC5100 that is a real workhorse. I've noticed that when sending jobs from Illustrator through Cutting Master 2, everything is off on the X axis by about an 1/8" of an inch. It repeats itself no matter what I try- I've offset the X setting but see no change. It cuts the job perfectly in every other aspect, only with the above mentioned issue.
Anyone else ever have this problem?
