Fc7000-130 ARMS giving me trouble
quintana711
I have this cutter that has been good so far but today is really stressing me out. My Roland versacamm has a clogged head so I sent out my print and wanted to align to cut in the graphtec. I ve done it before with large stuff never little sticker because I would do that in the roland.
it just keeps giving me a align error I dont know if any of you have some advice on this..
I now have a bunch of stickers printed and laminated that need a contour cut.
I, ve been trying for like two hours now I am about to give up.
GRAPHTEC
hey,
What do you mean by align error? on a Graphtec the only ALIGN error you get is a "realign roller" error message when you don't have your push rollers on the correct position(underneath a black sticker), what software are you using?
**now, if you mean that once it cuts the cuts are off then try the Sensor offset Adj.: this is the sensor calibration- you can find step by step in your users manual under Sensor Offset Adjustmen.
Here are some links to some instructional pdf's and vids:
if using flexisign:
http://www.graphtecamerica.com/FAQs/flexi.html
if using Adobe/ or corel draw along w/ the CM2 plug in:
http://www.graphtecamerica.com/FAQs/cutting_master2.html
hope this helps
David6ft6
Hi, I ran into this problem myself. I found that going from just contour cutting vinyl to contour cutting vinyl with laminate I had to go through the arms menu and select arms sensor adjustment. When I did this it worked prefect until I had to cut something different.
Hope this helps,
David
