FC7000-75 Contour & Perf Cuts on printed vinyl
Bigdawg
Just Me
I have set up this plotter to do a perf cut using Graphtec's cutting master 2 interface, but I'm not having any luck with it. I can set up the conditions and do a test cut (which works perfectly), but then the job just sets in the queue and doesn't seem to be talking to the cutter.
I cut vinyl out of Flexi on this - not with this software, but for some reason the cutting master doesn't seem to communicate with the cutter - it won't even do a media width inquiry.
Anyone else use this and could help me out on what I am missing? I can't find anything in either the program or the cutter manual.
Any thoughts?
SignosaurusRex
Check out the supports/downloads page at graphtecamerica.com They have "how to" video downloads for cutting master. I believe there is one that will help you with your question.
Case
The plotter needs to be set to GPGL language for the cutting master plug-in... It's set to HPGL for Flexi, Omega, Cut Server(onyx), etc...
Case
