FC7000 origin start point
Discussion in 'Graphtec' started by RidgewoodSignal_JO, Mar 3, 2010.
  1. RidgewoodSignal_JO
    RidgewoodSignal_JO New Member
    23
    I accidently changed my origin start point from Upper right to Lower left and cannot remember how to switch it back, any help??
  2. Kwiksigns
    Kwiksigns wookie
    591
    3
    18
    Feb 17, 2009
    Beltsville, MD
    When the COMMAND setting is HP-GL, the origin point can be set to either the
    lower left corner or center of the plotting area. When the COMMAND setting is GPGL,
    this parameter is not available.
    SETTING PROCEDURE
    1 Press the MENU key.
    2 Press the NEXT key until the following menu appears.
    3 Press the F2 key (AREA PARAMETERS). The following menu appears.
    Note: ORIGIN is only displayed when the COMMAND setting is HP-GL.
    4 Press the F1 key (ORIGIN). The following menu appears.
    5 The asterisk “*” indicates the currently selected setting. Press the F3 key to
    select LOWER LEFT. Press the F4 key to select CENTER.
    6 Press the ENTER key to register your settings.
    7 Press the MENU key to return the plotter to Ready status.
    Is that what you mean?
  3. RidgewoodSignal_JO
    23
    That was it
    That did it thanks!
