Need Help FC9000 or GR2 in Flexi 10
Vassago
You'd only be able to use basic interfaces - virtually all plotters use variants of hpgl - they just add extras to it.
If you use an older driver, you can't use things like barcode scanners or auto alignment - if the highest version driver supported it, you might have a chance, but it's basically the lowest common denominator.
I have had luck with modifying some drivers, but it's not guaranteed to work. All depends on if they've rewritten them, or just updated them.
kheebl
Member
When I set my fc9000-160 to hpgl and set flexi to use the 8000-160 driver when I send a cut to the plotter the fc9000 makes a noise for a second then doesn’t do anything. I have thought about trying to hook it up via Ethernet and see what happens I just haven’t had time to buy a longer cable. I’m a 1 man shop so I only have 1 computer I send files from so usb has always worked fine for me. I wish I knew how to edit drivers
Vassago
Ah.. No.. Just leave it set to use the graphtec driver.. The 8000 driver should run the 9000 without any issues.
If you set the 9000 to hpgl, you'd use a hpgl driver instead. The graphtec driver would output extra bits, which the 9000 set to hpgl wouldn't understand.
kheebl
Member
I think I tried it with the plotter set to gpgl, but I’ll definitely give it another try tomorrow when I’m at the shop.
