ok hi sorry my first post is for help but i guess thats always the way .
i have a gerber spandex jetster46 apparently a re named rockhopper 1 amongst other things im told
i have digital print vinyl a mactac made vinyl jt5829 i think and using flexisign 8.1 print cut rip thingy
now i print out my pictureon vinyl and it has like channels if u can image a ploughed field and lines through print were the ink isnt covering the vinyl i hadenginneer out yesterday he has set new capping station ne w dampers new heads new ink and new pump and im still getting the print problems
the heaters i have set both to 50 the max
the front burns ur fingers and the one under the head is warm
had enginnner check them he says they both working fine i said how can it be if ones warm and othe ris hot when there meant to both be set at 50 he says its just the way as the fixer one is faceing theback of printer and front is facing up ect
does any one haveany ideas why it wont print a picture with out lines in it
