fire retardant substrate needed
Discussion in 'Materials' started by CanuckSigns, Jan 13, 2010.
  1. CanuckSigns
    CanuckSigns Very Active Member
    3,431
    397
    83
    Nov 11, 2008
    Ontario
    Does anyone know of a fire retardant substrate that has the following properties:
    lightweight
    paintable
    can be cut on router
    relatively inexpensive
    We got asked to quote a job that involves cutting 36" high letters and suspending them from the ceiling above a stage, my first thought was 1" thick foam, but it needs to be flame retardant.
    Any help would be appreciated
  2. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    17
    Question
    We are thinking of using Sign•Foam signs in signs at airport terminals.They have strict non flammable codes even although we are doing the signs for a BOOKSTORE, go figure. Does Sign•Foam have any fire rating and could it have with a specific paint finish?
    Answer
    We have Sign•Foam signs in many airports, as well schools, hotels and casinos. These places all tend to have strict fire codes. Each situation will have to be evaluated independently. We do have some flame spread and fire testing information available and we would be happy to provide that to you. Sign•Foam has a fire retardant built into the chemical formula and it is self-extinguishing. However, to the smoke that is generated it can not be rated as a “class A” building material.
    We know of several cases where signmakers use a fire-proof primer. Benjamin Moore make a fire-proof primer called “IronClad”. Often times the inspectors will accept the fire-specs of the primer as that of the whole sign. By all means, do your homework, if we can provide you with any specific information, please let us know.
    Thanks,
    Tech Support
  3. Idea Design
    Idea Design Very Active Member
    1,019
    2
    38
    Jul 12, 2005
    Now that's what I call an answer. Very nice.
