Need Help First time lamination problems
Lewis Roberts
Hi guys , new to the forum didn't know there were such great forums out there for this business ,i've been a designer for several years and recently ventured into printing the designs i produce, im having a few issues well mainly one with my laminator and hoping someone can point me in the right direction.
before anyone mentions it is yes a fairly cheap entry level laminator standard two roller design manual handle cranking. but it's all the funds can support at this time.
the main issue i have is when running material through especially when prints contain black they end up with slight streaks of darker black than others , almost like its been pressed more than the rest of the print but these streaks are only small and don't have any particular position or shape. Am i right thinking this is a pressure issue of some sort?
super thanks in advance
2B
There are MANY factors that can play into lamination
  • inconsistent pressure
  • inconsistent feed rate
  • warpped roller wheels
  • etc.
without a photo it is a guess to what is going on, that said the most common issue is called "SILVERING"
laminating pure black print
equippaint
Assuming its a manual table top type, when you tighten down the 2 handles/screws for the rollers, do them at the same time with both hands to try and feel that you have equal pressure. Get it snug then twist both equally a little more. Don't over tighten it. It sounds like you're putting too much pressure or its uneven. Might get some silvering too but it goes away in a day or so.
If its bigger, lower the upper roller until its basically just its weight on the lower, then tighten it just a hair more equally on each side.
ironchef
Sounds like slivering. we need pics to be sure. if it is slivering. that goes away in the sun. that tends to happen more with cheap laminate. try 3m 8508
Sent from my SM-G950U using Tapatalk
spooledUP7
Just a few rules of thumb to go by:
  • Make sure your laminate feed roll is taught. Loose feed swill result in an uneven marks and sometimes wrinkles. This tension will change as the diameter decreases so you need to always be on it.
  • Make sure the print feed is taught. Silvering, wrinkles and irregular marks can occur when the material doesn't have resistance while going in.
  • Raise your nip rollers away from each other when not using it. I am guilty of not doing this, but my guess is that with a cheaper laminator the nip rollers may be more prone to flat spots which could cause a line every rotation.
Otherwise without a photo it's hard to tell what you've got going on.
