Sigsn Factory
Hi !!!
So I'm thinking of replacing me black color print head. It hasn't worked for a couple of years and I recently started to clean the lines to see if I could make it work... Long story short got ink to flow to head from cartridge, so I removed the head and soaked it for a couple of days. I got most of the nozzles to work but I shorted out the actual head fuse (the one on the back of the head ) cause the head cable had some liquid on it when I plugged it back in. Anyways found this a very inexpensive print head on ebay... but I was reading about ranking and adjustments??? I don't know if anyone would be able to help!!!???!!!!
P.S. I spoke to guy that sells the heads and he told me as long as the printer is 4 color it should work... IDK if this is correct info.
