I had a head clogged about 50%...
After many powerful wash I soaked the head in a warm distilled water/cleaning fluid solution, I did it with the head still in place, approaching the head from the bottom with a tiny container filled with the solution...
Still nothing...
I then took the damper out and attached a syringe where the damper insert in the head...
With little pressure I was able to have water running... I did it where the other damper attach too...
Now unfortunately nothing fires anymore...
Did i burned the head?
If yes should I have an error message? Everything run smoothly electronically but the head just do not fire...
I have another head which was damaged with a bad scratch...
Could I eventually mix the chip of one head with the metal part of the one damaged today?
Thanks a lot for any advices...
Still nothing...
