We run a Jeti 1224 with the 30pl heads at 300x600 dpi.
1. Actual print speed on the production speed.
-For the type of work you describe- 6 minutes per 4x8 easy. (about 320 sf/hr). On the other hand, ultra high detail at about 18min per 4x8 (about 106 sf/hr), though I rarely run that slowly. Having said all that, for your work I'd recommend getting the 80pl heads and sacrificing a bit of resolution for higher speed.
How many passes your running to achieve 6 minute 4x8? Are you running at 2000mm/s? We tried to run a job, 400x800, 12pass, 1700mm/s and it was taking around 13minutes for a 4x8 sheet. We also have the 30pl heads.
This might be alittle off subject, but anyone else with a 1224 having ink issue? We are running the Flexform inks, and wanted to switch to the Sun Premium but Gandi told us not to since they are having issues in the field with the Premium inks wrecking heads. This is straight from Hary Gandi mouth. We are having issues with the Flexform ink, being expired, and clogging up heads. Once again, Hary told us not to worry about the expiration date on the inks(although there tech support site says the ink has a one year shelf life). All the inks we get from Gandi that aren't expired we don't have any issue with our jet outs. The inks that we get that are already expired(some expired by 4 months, dusty, and beat up containers) give us one heck of a time with our daily jet outs. We are ink priming those heads 3x as much as the others, and running 4x8 sheets of styrene of those colors just to get within the 5 jets out per head.
Also I'm really curious on the lamp prices. They seem really pricey for the size. Our 38" and 42" UV bulbs we have on our 6c automatic, and 200 watt dryer, go for around $180 a piece. We get them through Primarc, and they work better than any other bulb we've purchased. Our sales rep(Jackie) told me to get in touch with her when it's time to replace the bulbs in our 1224, since they probably could hook us up with a replacement.
