Flexi 10.5 Cut/Plot Issue
h2go4it
I recently upgraded from version 8.6 to 10.5. In the Cut/Plot manager, 10.5 does not work the same as 8.6 when working with margins in the Panel Tab. In all of the previous versions of Flexi, the margin for each color layer could be independently set, but in 10.5 it is a "global" function. In other words, if you change the panel margin in one layer, it changes all layers.
Does anyone know if there is a setting to change this? I would like to be able to set the outer most layer to a minimum margin, with all other layers having a larger margin so that the border on each layer matches. As I stated, all previous versions of Flexi up to and including 8.6 allowed you to set independent layer margins.
Thanks for any help.
eahicks
You have to select "Use Same Driver Options For All Colors" to retain any info for each layer. EDIT: nevermind I read your post wrong.
eahicks
Just draw a box around your artwork that you send with each color layer. Then each color has the same outer border. Pretty simple.
