Flexi 19 Color Management
Discussion in 'Flexi' started by FernwehPrinting, Sep 24, 2020.
  1. FernwehPrinting
    FernwehPrinting New Member
    4
    May 12, 2020
    Livingston
    Good evening!
    I'm looking for suggestions about color issues and the generic .icc profiles in Flexisign 19.
    I'm having an issue with yellow printing correctly on a Mutoh printer. When I print anything with alot of yellow or mixed with yellow (red, orange, green, etc) the colors come out dull and not vibrant like they should.
    I changed all the parts on the printer that could be causing the issue and still nothing has changed (good test prints, decent nozzle checks)
    Last year I was running an old version of Flexisign (Flexi 12 I believe) and didn't seem to have these issues but upgraded to Flexi 19. I'm curious if it could be the .icc profile?
    In Advanced Color Management:
    Originally I ran
    CMYK: GRACOL2006_Coated1v2
    RGB: sRGB IEC61966-2.1
    Gray: GRACOL2006_Coated1v2
    Since I've upgraded it's set to
    CMYK: U.S. Web Coated (SWOP) v2
    RGB: Adobe RGB (1998)
    Gray: U.S. Web Coated (SWOP) v2
    When I switch to the original profiles after upgrading the colors started coming out much darker than they should have been.
    Could the profiles be the issue and is there any suggestions for better profiles?
    Thank you for your time!
  2. ColorCrest
    ColorCrest Active Member
    749
    104
    43
    Dec 11, 2017
    So Cal
    Be sure to choose the proper ICC output profile for your Mutoh's media and print mode. What is the full name of that ICC output profile?
  3. karst41
    karst41 Member
    148
    25
    28
    Nov 3, 2010
    Stone Mountain, GA
    With FS you have Two Options:
    Color Correction, which works very well with the Pantone Color Bridge CMYK Values.
    however, these colors look like mud across the board.
    No Color Correction: Yes you can be all day dialing in a color and run off 5 yards of material. (I buy cheap psa vinyl just for this) However if you change a printhead you
    will be dialing in that color again.
    To illustrate this Print a swatch of PMS 286 Use Color Correction
    Now print another swatch C100/M85/Y0/K0, Here you should see a deep and vibrant PMS 286 that is aFormula Guide match.
    You do have a Pantone Color Bridge?
    If not, Get One.
    I print mostly Gloss so therefore I use the Coated Stock Guide.
    If you print Matte Vinyl, you need the UnCoated Stock Guide.
    Hope this helps.
  4. myront
    myront CorelDRAW is best
    1,476
    281
    83
    Dec 3, 2015
    Niceville, FL
    You didn't mention what type of file you're printing. We have found that using Pantone colors will produce the best color output. 90% pdf's but if too raster heavy, RGB tiff @ 150dpi.
