Flexi 7.0 on Windows XP Pro Sp2 not print
Discussion in 'Flexi' started by adikto, Aug 31, 2005.
  1. adikto
    adikto New Member
    2
    Hello, I'm spanish and sorry for my bad english.
    I have a mutoh 4100 on LPT1. I've updated my computer from Win98 to XP pro SP2 and works fine with my plotter IOLine on Com1 but not print on LPT1, stops at 3% printing and the system stay veeery ralentized.
    Any ideas please
  2. iSign
    iSign Major Contributor
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    I don't have much to offer, but I can say that I print to my Mimaki from Flexi 7.6 on XP pro SP2 & it works for me. I think you should get the Flexi upgrades. It is probably very inexpensive if you are already at 7.0 & I think there are many improvements. Maybe that will even get you fixed up.
  3. gtjet
    gtjet Active Member
    763
    I would un-install the driver and re-install it, that may help. There are issues with XP and service pack 2 but when we upgraded the uninstall and re-install worked for us.
    Also we are running Flexi 7.5v5 so maybe that is helping too. Your english is great but my son has 4 years of spanish and if ever needed he or maybe one of his instructor could help but from what I see, you have very good english skills.
  4. Fred Weiss
    Fred Weiss Merchant Member
    20,923
    547
    113
    Sep 11, 2003
    Olympia, WA
    With regard to upgrading your FlexiSign ... providing you are a registered owner of a 7.0 license, all upgrades to the current 7.6v2 are free of charge. You should definitely look into getting the current version installed on your system.
  5. Kevin Huffman
    Kevin Huffman Member
    36
    Hello Adikto,
    When you updated from Win98 to WinXp did you do a complete format of the hard driver and install a new set of windows or did you just update win98 to winXP?
    I have never had luck with just updating, something's just never seem to act right or connect up properly.
    I would suggest backing up all the files you want to save on cd or another hard drive and do a fresh clean install of windows on a blank hard drive.
    Yes, I would also get the update from 7.0 to 7.6v2 also, there has been many fixes/patches since the original 7.0 release.
  6. Derf
    Derf Very Active Member
    I had a similar problem!
    I woud up grade to 7.6v2 then Uninstall SP2 from Windows or there is a step by step process you can go through to work around the "Open Port Error" problem, just go to www.scanvecamiable.com and download the PDF file with the work around.
    Also you may just need to set up your printer to RIP & print at the same time. That helped me out big time
    Good luck
  7. adikto
    adikto New Member
    2
    I'm very grateful for all your advices. Try to get v7.6.
    Saludos
