Flexi 7.5 and Windows 7
Phil Swanson
Can I run Flexi 7.5 on Windows 7? My computer says that Flexi is looking for ( or trying to use) Win XP but XP was never installed on this computer.
Now it seems like it wants to open but it won't read the key. It says an application key is required but was not found. The key is in and lights up.
Try this:
Right click on the application and select properties. A window will pop up and you want to click the "Compatibility" tab. Under that tab there will be an option called "Compatibility Mode". Click the check box to activate it and select Windows XP (Service Pack 3). At the bottom of the window is an option called "Privilege Level" check the box that says "Run this program as an administrator". Click apply and then exit that window. Now open the software again and it should work.
I'm not sure if this works on the shortcut icon on your desktop and you may have to find the Flexi folder to do this to the actual application file. Good luck!
