Flexi 8.6v1 Cutter options disapearing act???
Discussion in 'Flexi' started by Fuzzbuster, Feb 25, 2009.
  1. Fuzzbuster
    Fuzzbuster Active Member
    554
    Mar 23, 2008
    Ottawa
    Hey guys
    tried a search to no avail
    Gotta quick one for ya
    Using Flexi 8.6v1
    Trying it for rip/print and Cut... used to Onyx
    When i go to the production manager to send to cutter after rip/print... my cutter driver options Vanish???
    am I hitting something wrong
    The cutter is cutting but with diferent pressure and speed values...
    was using this before and i could go into plot drivers and change cutter settings???? WT:help
    Help:help
    Thanx in advance
  2. Fuzzbuster
    554
    Mar 23, 2008
    Ottawa
    Bump
    Anyone???
  3. Dave L.
    Dave L. Member
    126
    May 2, 2008
    USA
    I'm assuming that the Add Setup was done correctly and the drivers etc. are just not taking. Make sure that your cutter is selected in the Rip and Print and you are using the PM settings. You'll see that tab come up from time to time that will ask you to use default (Machine) or PM (RIP) settings. Hope i was of a little help, keep us posted
  4. Fuzzbuster
    554
    Mar 23, 2008
    Ottawa
    Just looked at it again
    My pressure and speed settings are there in the default settings but when i go into the tab beside the print driver option...(the contour tab in advanced), and go to driver options there ... there are no selections for pressure and speed
    when i contour cut a print job from PM ...its cutting with too much pressure...
    I`m sure i had those options there before...i dont get it
    they freakin disapeared
