Flexi 8 w/ USB cutter HELP!
Discussion in 'Flexi' started by decals, Aug 19, 2010.
  1. decals
    decals Member
    29
    I'm sure this is probably pretty easy for some of you, but not me, so bear with me here. I got the wife a rather large cutter, a 36" Desay Master XY-380P. Anyhow, it's got one of those 25 pin serial cable deals, and she wanted to be able to hook it to her laptop, which only seems to have USB.
    Not a problem, I found an adapter.
    The problem, however, is that I have no idea how to configure Flexi to cut via USB. There are COM and LPT ports, but nothing it showing for USB and I cant seem to find anything in the manual.
    HELP!!!
  2. LizardWraps
    LizardWraps Member
    69
    Mar 26, 2008
    call sai.. I had the same Problem.. They dialed in and fixed it in a second for me.
  3. CS-SignSupply
    CS-SignSupply Very Active Member
    Call me in the morning and I will help. The trick really isn't a flexi/USB issue.... More of an adapter setting issue.
