Flexi 8 with Windows 7
I have used it with windows 7 and have even installed the older Mutoh version of Flexi on Windows 8. You just need to make sure you have the 64bit drivers installed for your machine if it connects using USB. Ethernet doesn't require a driver so if you are using a Mutoh or other networkable machine, there shouldn't be a problem.
RG
Today I installed Flexi 8.1 on a new Windows 7 machine. It seemed to install OK, but it hung up when it started ripping. It gave an error code 6. I made Flexi & Production Manager compatible with XP SP3 and the problem was solved. If the Cloud had any good profiles for an Edge 2 printer, I would drop 8.1 completely.
