Flexi and defaults.
Discussion in 'Flexi' started by gabagoo, Aug 11, 2008.
  1. gabagoo
    gabagoo Major Contributor
    5,750
    110
    63
    Oct 10, 2006
    Vaughan, Ontario
    I have yet to figure this out with Flexi for Rip & Print, but I can think of no other explanation. I set up my cutter to cut in a sequential manner and when finished cutting the head should go to the end of the graphic and not the beginning. Now by the time I had figured out where to find those options I may have been printing for 6 months or so. I now find my cutter is cutting things out of sequence and bringing the head back to the beginning. I never changed it but I have an idea that the software if opening an old file goes back to the defaults of that old job and then stays there for any new jobs, which is very aggrevating. Would I be correct about this as I can't figure out any other way that it keeps changing it's defaults.:bushmill:
  2. Replicator
    Replicator Major Contributor
    10,230
    10
    38
    Nov 19, 2006
    Sun City, AZ
    I have a Roland CX-300 and I use Flexi the majority of the time to cut my vinyl . . .
    I have found that's it's not Flexi making the decisions about start and end points, but rather the cutter,
    also I've found the the vinyl is usually cut it the order it was created in the file,
    that is probably a Flexi thing, so out of order is usually the norm for the cutting around here !
  3. DRPSignsNGrafix
    DRPSignsNGrafix Very Active Member
    Make sure the changes are set in PM not in Flexi. The plotter will always go by PM it overrides everything else.
  4. gabagoo
    5,750
    110
    63
    Oct 10, 2006
    Vaughan, Ontario
    Thanks, but now I must find in PM where those settings are...lol
  5. DRPSignsNGrafix
    open PM and at top select setup down to job defaults
