Flexi and PhotoPrint RIP
SightLine
Both are made by SAi....
Essentially the same rip and profiles should be compatible with each as far as I'm aware. I think they have done away with the "Photoprint" specific version and now just offer Flexi and Pixel Blaster. I think Photoprint was really more geared towards print only while Flexi had more features for design and running cutters in addition to print.
John Thomson
This will be a cut down version of Photoprint that only has drivers for the suppliers printer.
You can take these drivers and drop them into Flexisign.
This is what I have done with my Chinese printer..
Joh
deand_sai
I'm looking at getting a new printer and the machine comes with PhotoPrint RIP. After googling it looks exactly like Flexi. Is Flexi made by http://www.taimes.net/p/photoprint-rip-software.html
Anyway are the profiles interchangeable? I wouldn't mind having only one RIP to drive my other printer in addition to this.
PhotoPPRINT and FlexiSIGN are the same thing, just different names and features. The drivers and profiles are interchangeable if the version is the same. But if you have a Version 10.5 driver in PhotoPRINT it wont work in FlexiSIGN Version 11. So make sure the versions match.
gabagoo
I have used photoprint for 7 years with my Mimaki and it is simply print or print and cut, but not cut only, which is fine as I run Signlab for everything else. If I ever upgrade printers the fear is that switching from photoprint makes all those thousands of files pretty much useless I suppose....I am a prisoner!!!:banghead:
