Flexi CLoud Printing fragments
Shift Designs
anyone else had this issue with printing in flexi cloud. see pic of thin black line
chrisphilipps
What printer are you using and does it do it on the printer's internal test? I have seen a 64" Mutoh Valuejet do this and it was caused by a failed ram chip on the mother board. We replaced the ram and the problem went away. See attached pictures
Shift Designs
Its a Mutoh TOUCAN LT. It only does it when flexi is using some sort of marker or border. If it is a group of contour cut stickers, it places a line only where the sticker falls right below each sticker, cut that the only place. That and where the crop marks fall. I wasnt having this issue untill i started using flexi cloud.
Shift Designs
just tested on Flexi 8.1 and problem does not exist when printing with this version of FLexi
Shift Designs
are you printing with so diffusion dither mode when you were getting this.
i dont get it when printing with fm express dither mode
chrisphilipps
We only print in SO Diffusion at this point. I would call SAi's tech support and let them know about it. Sounds like there is a bug in the driver.
chrisphilipps
I just heard back from SAi they want to know what printing resolution are you using when printing this? Does it happen with different resolutions and different profiles?
