Flexi gradients in later versions fixed?
Discussion in 'Flexi' started by Gene@mpls, May 13, 2011.
  1. Gene@mpls
    Gene@mpls Very Active Member
    2,017
    92
    48
    Jun 17, 2003
    Blaine, Mn
    I know that Flexi 7.6 has problems with gradients- has that been fixed
    in later versions? Thanks Gene
  2. chrisphilipps
    chrisphilipps Merchant Member
    654
    18
    18
    Jun 5, 2009
    Wharton, NJ
    If you are referring to the stepping in prints than yes that has been fixed. The problem is actually caused by the Dithering Method and you might be able to get it to work in your version by changing it from FMXPress to Error Diffusion. The only downside is it will take about 5x longer to rip. In Flexi 8.6 and newer they have a dithering method called SO Diffusion that corrects the issue and also offers quicker rip times.
