Flexi how to cut a smooth line
Discussion in 'Flexi' started by deadguy141, Jan 18, 2007.
  1. deadguy141
    deadguy141 New Member
    4
    Hello, I'm having trouble cutting a smooth line with flexi design. I scanned a pic of a sticker I wanted to cut. Once you import the pic to flexi, the edges look ok. If you zoom in you can see how jagged it is. When you cut it, it comes out jagged and not smooth. I was wondering if there is a way in flexi to smooth out the lines. Thank you
    James
  2. Pat Whatley
    Pat Whatley Major Contributor
    8,577
    81
    48
    Sep 29, 2003
    Wetumpka, AL
    You can adjust the tracing options a bit to get it a little better, but all in all Flexi tracing has SUCKED since version 5.
    If you've got Corel or Illustrator they will both do a better job of tracing it. If not then you're gonna have to redraw it instead of trace it.
  3. Mike Paul
    Mike Paul Major Contributor
    5,437
    8
    38
    Dec 30, 2003
    NJ
    Try the Bezier trace option.
    Use your path edit tools to smooth the lines.
  4. GregT
    GregT Very Active Member
    You can always go in and get rid of the nodes. To many nodes will make it rough.
  5. mtmdesigns
    mtmdesigns Active Member
    584
    Send it over to the vector doctor. Or autotrace and learn the hard way.
  6. MAB SIGNS
    MAB SIGNS Very Active Member
    1,027
    the nodes have it...
  7. mtmdesigns
    584
    I dont think he knows the nodes just yet from reading his post. Scanning and tracing is a good way to learn though.
