flexi layering help please
rgaskins
Im trying to figure this one out, sure its easy for someone but I'm going crazy here...If you open the attached file, I would like to print everything but the red, I would like to use a floresent color in its place...Problem is I'm trying to make the red cut out so I can jut lay it on top the printed design....Can someone please explain how to do this...Thanks for any help!
Rick
  • trick olimpic1.pdf
mikey-Oh
why not lay the print on top of the florescent shape?
otherwise just copy everything else, make a solid color combine/merge and knockout/cutout the blob from the trapezoid
