Sign Works
I've got a customer supplied file in .AI & .EPS format which was created in Illustrator CS2. When I attempt to open or import it into Flexi 8 the gradient fills do not show up. The greadient fills are created using a pantone color and then 40% of the same color at the lighter end, Is this considered a transparency and is that why Flexi wont read it? It is also strange when I do open it in Flexi it appears that each element/path has a mask applied but this dosen't show in the file in Illustrator, also in Flexi the outer dimensions of each mask are equal to the document/page size in Illustrator (8 1/2" x 11") any ideas?
