Flexi Parallel Hasp
timc
I've just switched to a new machine running win7. I have flexi 7.6 and it has a parallel port hasp. I've installed a PCIe card with parallel port and it works fine (printer prints, port is recognized in device manager, etc).
I've set the port as lpt1. I installed win7 pro and downloaded xp mode software, and this all works fine. (I have high end accounting software that also required xp mode and it works fine).
Installed flexi and when I start it up it says key is not found. I do not have the printer attached when trying this.
The hasp has the name 'memohasp-1' on it. I have searched and cannot find a driver that will help my machine recognize the hasp. And scanvec-Amiable just says to upgrade and get a new key.
Does anyone know a workaround for this. Or maybe a driver I need.
Thanks in advance-
choucove
I believe the driver for the parallel key that is used by Flexi is called the aladdin key, so try doing a search on google for aladdin hasp key driver and see what you can find. I might be wrong, as I am used to the USB keys which use the sentinel driver.
