Flexi pdf export probem
Discussion in 'Flexi' started by Hellagfx, Oct 26, 2020.
  1. Hellagfx
    Hellagfx New Member
    4
    Aug 8, 2009
    Coldwater mi
    So I recently upgraded to flexi 19 from 10. I have a weird problem that now when I export a pdf, flexi sizes the file up very slightly. File would be 48x96 but flexi exports it 48.005x96.005. I know that does not seem like much but it does throw off my rip program with the cut file. When I export in eps or jpg the file size does not change. Only pdf.
  2. jimboeejit
    jimboeejit Member
    83
    22
    8
    Apr 30, 2020
    uk
    are the measurements in working page...export...etc all the same?..
    ie..cm...mm..inch etc
    sometimes it converts to default cm if working
    in mm and inches
    just a thought
    • Like Like x 1
  3. fuzzy_cam
    fuzzy_cam The Granbury Wrap & Sign Guy
    156
    33
    28
    Mar 7, 2017
    Granbury, TX
    When exporting... Select what you want to export, then hit export - should open up the 'Save As/Export Window' Be sure and select 'Selection Only' and deselect 'Suppress Options'. When you click save another window will open allowing you to select what scale you want to export as.
    • Like Like x 1
