Flexi question!!!
PMG
What is the max file size that can be used in flexi,i am working on a file,and am using a Aurora fill and the files is 7mb total ,and Flexi says when im saving it that i am out of memory to restart flexi....as soon as i take the fill out it saves just fine i have a dual core and 3 gigs of memory .................:help:
Geary
Sure sounds like you have enough of BOTH kinds of memory. Just try defragging and reboot.
Btw, what happened to your "2x 250 gig"s of storage space and your "4 gig Memory" ??
PMG
I had 4 gigs in this pc and took 1 out to place in another PC and Just never updated it!!!!
Mike Paul
Super Active Member
7 megs? That's a small file and Flexi 8 should handle it fine.
Do you have multiple masks or lens filters applied to the artwork?
What happens if you rasterize the file and export it as a bitmap?
PMG
Turning the mem up helped a great deal....... i set it at the max which doubled it from what it was set at..thanks for the input guys!!
PMG
I just have a 1 transparent lens on 1 fill!!
