flexi question
auto accents sc
We use Vinyl express 7.5 which is basically Flexi Pro. Recently we were sent artwork for a wrap. When we imported the ai file the font changed also the kerning was off. We also imported a pdf of the art and the same thing happened. I don't have any experience with printing. We are using an outside shop for that. Does anybody know what is happening?
Thanks dastripeman
anthony smith
when they save the file they must convert the fonts to curves or your system will
read and try to change
If not that they will need to send you the font they used and you will have to download
to yours
DRamm76
They would def need to convert all fonts to outlines or curves. What version of Illustrator are they using to create it? While Vinyl Express 7.5 is similar to Flexi, depending on what version they are using it may not import files in versions of software created after 7.6 was released. May NOT be the solution, but might be worth a shot to have them save it as an EPS as a lower version if that is possible
Marie
Do you have a copy of Illustrator? If so, open a new illustrator document, place the file with the font problem, then with the graphic selected, pick Object/Flatten Transparency. Set the scale to 100 and check convert fonts to outlines. Otherwise, get them to resend it with fonts already converted - Good Luck :)
