Need Help Suggestions Software Help Flexi sign production manager
Discussion in 'General Chit-Chat' started by Simplistic designs, Sep 21, 2020.
  1. Simplistic designs
    Simplistic designs New Member
    2
    Sep 15, 2020
    Penal
    Getting this error"caught exception,error code -6"
    Any ideas on what to is or how to remove it only comes up when I'm doing a rip and print function
    Using a windows 7 computer
    Flexi sign8.1v1
  2. Dale D
    Dale D New Member
    15
    Sep 15, 2020
    Maryland
    Someone I knew had the same problem and contacted Flexi.
    Here was their response:
    Unfortunately Flexi 8.0/8.1 is only compatible with Windows XP 32 bit and not Windows 7.
    I would suggest you to either downgrade Windows to match the older version of Flexi or upgrade Flexi to match the new version of Windows.
  3. karst41
    karst41 Member
    146
    25
    28
    Nov 3, 2010
    Stone Mountain, GA
    Definitely one of my favorite pairings over the years.
    Great answer by Dale
    Win XP 32 was one of my favorite versions of windows and with FS 8.1 Seldom did I have a issue.
    You can go on eBay and find a pristine computer with XP 32 for next to nothing. Get a video card with 1mg ram and all the system ram that you can shove into the box. The Ram will probably cost more than everything else.
    If you are using a bootleg version of 8.1 why? You can find that version cheap and Ver 10 for less than $1000. FS supports only 11 and up.
    Cheers
  4. netsol
    netsol Active Member
    750
    103
    43
    Apr 26, 2016
    englishtown, nj
    • Agree Agree x 1
  5. WildWestDesigns
    WildWestDesigns Major Contributor
    6,534
    322
    83
    Sep 27, 2010
    Mid TN
    VMing would depend on if the specs of the computer can accommodate running essentially 2 computers at the same time.
    If the OPs Win 7 computer is Pro or Enterprise, I think should be able to still get a free copy of XP to VM within VirtualPC. Called XPM (or XP Mode) by some.
    I'm one that very much prefers to solve things like this via software (VM software in this case) then trying to maintain EOL hardware as well. I still run Win 98 using this method (my preferred version of Win ironically, I hated XP and XP kinda sucked until it had a couple of SPs under it's built).
  6. WyoRichard
    WyoRichard New Member
    3
    Sep 16, 2020
    Laramie
    Would it work if you ran the Flexi 8 under Windows XP Compatibility mode? Trying that would first would be way easier than setting up a Virtual Windows XP.
    • Agree Agree x 1
  7. Attila Nagy
    Attila Nagy New Member
    18
    1
    3
    Sep 24, 2018
    London
    I had the same error with 7.6v2 on 64bit win 7, but not with 8.1. I can cut, rip and print using 8.1 0n W10 or W7 64.
    On Win10 32bit 7.6v2 and 8.1 both just work fine. It still could be compatibility problem with the ports. I am using ECP printer port for the Gerber Edge2 and network for the Mutoh Printer.
    If 3G memory is enough, try 32bit system
Similar Threads - Flexi sign production
  1. montague
    8
    519
  2. Jmie
    Need Help flexisign help
    Jmie, Sep 21, 2020, in forum: Flexi
    8
    532
  3. lbpalm
    6
    646
  4. gabagoo
    2
    462
  5. lbpalm
    8
    554
