Flexi, we have a problem.
Discussion in 'Flexi' started by Bradster941, Sep 25, 2005.
  1. Bradster941
    Bradster941 Very Active Member
    2,190
    Major Newbie here. :rolleyes:
    I just bought a cutter that came with Flexi starter and while it will allow me to put text and graphics on the work area, it will only cut the text and not the graphic unless it is a (AI)? Type of file. Bitmap, Tiff, Jpeg will all import but not cut.(No cuttable object with current setting). EPS files will not load at all.
    <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
    The online manual and the quick reference guide sheet show all kinds of options like Rip and Trace, Design Central, Path Edit tool, etc., that simply do not appear in the tool bars or menus section across the top.
    <o:p></o:p>
    So I’m guessing this is a majorly stripped down version and the only way to get it to work is to upgrade? Or do I have other options?
    <o:p></o:p>
    Ps, I bought this for personal use, not for a sign business.
    <o:p></o:p>
    Thanks much, :thankyou:
    <o:p></o:p>
    Bradster…..
  2. VinylCraft
    VinylCraft Active Member
    732
    Some options maybe alot are limited on Starter being the barebones i belive. You may want to view a simaler post
    Flexi wont cut
    by SAS
    Flexi
    But i can't see why you couldn't open EPS. I would say if you plan on doing anything with flexi you really need to upgrade
  3. Fred Weiss
    Fred Weiss Merchant Member
    20,920
    545
    113
    Sep 11, 2003
    Olympia, WA
    It will open EPS ... it sees AI and EPS as one in the same.
    It takes vectors to cut vinyl. Bitmaps can only be traced first to create vectors and then the vectors can be cut.
    If you're in it for personal use, get a licensed copy of CorelDRAW or Adobe Illustrator and then use the Flexi starter software to output the vector files you create in the other software. If you're in it for eventual creation and production of computer graphics on a full time basis, upgrade the Flexi.
  4. Bradster941
    2,190
    Thanks Guys,
    Fred, how much is an upgrade?
    I went to Flexies web site but could get no answers, just “contact me” when looking for prices.
    And no, I’m just playing around here, not a business intent. And my wife has sternly informed me I’ve already spent to much money !… :Oops:
    Many thanks,
    Bradster… :glasses: :thumb: :Big Laugh
  5. VinylCraft
    732
    FlexiSIGN Software - New Flexi 7.5 Version $1,695.00
    FlexiSIGN PRO Software - New Flexi 7.5 Version $4,295.00
  6. Bradster941
    2,190
    OUCH !!!
    Pretty steep as all I want to do is put a 20" smiley face on the side of my boat!! :peace!:
    Thanks for the quick price check on isle 4 though!!!...:thumb:
  7. Bigdawg
    Bigdawg Just Me
    7,462
    133
    63
    Jun 8, 2005
    Sunny Florida
    Hey brad - if you save the eps as Illustrator 7 format I think it will import into the starter version. Any Illustrator version newer than that it doesn't seem to recognize.
