Flexi12 w/SP300v - blade offsets?
lodcomm
Hi folks,
what blade offset do you use for a 45 degree blade and a 60 degree blade. for a 45 I use .250mm in versaworks. Flexi wants the offset in inches. I converted the .250mm to inches and t gave me 0.0098
I set that into flexi as .01 but am still getting horns on my corners?
can you suggest a good offset for the two blade's
thanks!
-todd
45 degree - 0.25 mm
60 degree - 0.10 mm
Usually I set it on the printer and tell the RIP to use the printer setting. It's a set value anyway and should not change.
lodcomm
45 degree - 0.25 mm
60 degree - 0.10 mm
Yes, that is probably the way to do it is just set it on the printer.
-thanks
