mnapuran
Okay... is there not a way to have Flexi do cutting wherever you want it to?
For example.... let's say you have a shape resembling an O (or anything with an inside to it for example). You can contour cut around it after printing it by using the standard contour cut tool, BUT how can you define a cut line INSIDE as well? So that all you are left with is the O itself, and not an O with vinyl on the inside.
Hope I explained this in a way that's easy enough to understand![Wink :wink: :wink:](https://signs101.com/images/smilies-orig/standard/wink.gif)
