Flexisign & Print 12
Discussion in 'Designs & Layouts' started by morty87, Oct 16, 2018.
  1. morty87
    morty87 Member
    122
    5
    18
    Feb 17, 2018
    Vancouver
    Hello, I am adding 3 - 12x12 images into my flexisign 12 and I want to add a 2 inch bleed with each image. My media is 54" across. When I send the design it groups the 3 images together and does the bleed around the outside of the 3 images. In the job properties it does not let me break them apart. I must be missing something cause I can't believe you can only do 1 print at a time with a bleed on it? My media is 54" across so there is lots of room there is a break them apart otion but it is greyed out.
    Anyone able to help?
    Thank you
  2. bannertime
    bannertime Very Active Member
    2,160
    505
    113
    Sep 8, 2016
    No
    When you send an image from Flexi into Production Manager, PM treats the file as one image. You'll need to send each image one at a time, nest them, and then click each one and add bleeds to it, set your print settings and send it. Warning though, if you set all your bleeds and settings and then choose a preset, it'll reset everything you just did. So if you are using a preset, nest first, set the preset, and then do the bleeds.
