Unfortunately, no. They said this was the first they'd heard of this problem and would 'look into it'.flexi people could not help you?
I'll try that test and see what happens. Yes, I've searched for the file but with no luck. Will let you know how the test goes.Maybe if you set those for a specific folder and then try a test? Probably not but might be worth looking at.Of course you have searched your hard drives for *.fs ?(or whatever extention you are looking for). Or make a file and save it and search for that specific name...
Tried it. That's what's driving me crazy, I've tried everything that SHOULD fix it, but no dice.how about opening preference manager and resetting to factory default?
I think it's an issue with Flexi 10. Try upgrading to Flexi 10.5 PDF.
I'll give this a shot this weekend while the shop is closed. I can't take my station offline that long while we're open. I'll let you know if it helps, thanks!Re-install the Flexi software into a clean directory and re-try.
IE: c:/program files/SAI_NEW/... rather than c:/program files/SAI/...
