F1225hgB42w
Guest
Hey Everybody!
We've started doing more direct printing in our shop on a Fuji Acuity with KI inks (we upgraded from KO inks to try and solve issues with dark ink coverage chipping out on Foam Board - lets say 300% plus). We use a knife system with a drag knife to finish cutting out foam board direct prints. In areas of heavy coverage we have ink chip out and don't know how to solve it! Any help is much appreciated!!!
Summary:
3/16 Foam Board - Direct Print with Fuji Acuity KI ink set
Cutting with a drag knife on a cnc/knife system
Inks chip out along the edge of foam board in heavy ink coverage - we need help to stop this from happening
Thoughts:
- Could we use a different UV curing setting - our Acuity goes from level 2 cure up to level 5 cure (5 is the strongest cure)?
- Is there a knifing strategy we should try (we run 500 in./min. in a climb direction)?
- Should we let our inks sit longer before cutting (we typically cut within a few hours of printing)? How long should we wait until cutting - 24 hours 48 hours?
Thanks again for all the help!
Summary:
Thoughts:
