d fleming
Just used a little trick on a problem job. Hope it might help someone with future installs of this type. Had to install quite a few 1/2" foam board graphics at a retail store. All using scissor lift. VHB tape and silicone to hang. Done it this way a long time with no issues. Well, about half of them fell the first night. Turns out the contractor had to put 5 coats of paint on the sheet rock to cover maroon with orange. Guessing that was the problem. Maybe not, who knows. The silicone simply would not cure. Not all the vhb worked either. Replaced damaged signs this morning, switched to oracal tape instead of 3m because the 3m just didn't feel very tacky to the touch. Oracal did. That stuff is serious. This time I took some small rivets, cut the heads so they would not go all the way through the board, drilled the wall at tops of each sign for rivets to be push in to the sheet rock. The collars on the rivets worked to stop the rivet from going any further into the wall than needed. Pushed the signs on to the rivets with a ridiculous amount of tape on the back. Those jokers are staying. Happy Turkey Day Y'all.
