Font installation...
Discussion in 'Signlab' started by Dave Drane, Jan 16, 2006.
  1. Dave Drane
    Dave Drane Very Active Member
    2,540
    1
    Last year I upgraded from Win.'98 to XP. I installed the fonts with no worries but I went to use one yesterday and it wasn't there. It is resident in windows but it just won't install for some reason. I thought maybe I had too many installed so I deleted some of the useless ones and it still wont install.
    It installed into VMP Ok but when it did show up in the font list it just read "unable to install xxxxx"
    Can anyone give me a few pointers i may have moissed??:thankyou:
  2. kevco
    kevco Guest
    have you tried a BMFH?:Big Laugh Other than that I can't help you but good luck in getting it fixed.
  3. Dave Drane
    2,540
    1
    Yeah, tried that one Kev. I don't want to reset the Font base if I don't have to as it will take forever picking out the ones I want.
    Just wondered if there was a simple solution.
  4. Fred Weiss
    Fred Weiss Merchant Member
    20,920
    544
    113
    Sep 11, 2003
    Olympia, WA
    Dave ... zip the font and send it to me. I'll check it out and let you know if it's the font or something else.
  5. Dave Drane
    2,540
    1
    Thanks...
    Fred, I have sent it off for examination by a pro.:U Rock:
  6. Ian Stewart-Koster
    Ian Stewart-Koster Active Member
    936
    23
    18
    Sep 27, 2003
    Qld, Australia
    Hi dave, I installed "The font thing" a long time ago and like it. I also sometimes have a font appear to be 'not there'. The font thing will catalogue all fonts on your computer- the installed ones, and the others that you can keep in a spare folder or folders somewhere else on your hard drive. You then just refind the missing one from another supply that you put there as you don't trust computers anyway, and right click and <install> and it's there.
    You will usually have to shut down the sign program & restart it for the new font to be found again.
    The font thing is here: http://members.ozemail.com.au/~scef/tft.html
    Hope that helps!
  7. Fred Weiss
    20,920
    544
    113
    Sep 11, 2003
    Olympia, WA
    I can't find anything wrong with it Dave. It looks unflawed under close inspection and installs and shows up in my applications just fine.
    Double checking some basics: Are you using the Control Panel > Fonts > Install command to install your fonts?
  8. GB2
    GB2 Very Active Member
    1,988
    97
    48
    Nov 15, 2005
    Connecticut, USA
    On a similar note...can anyone briefly describe the recommended procedure for Un-Installing fonts via the Font folder in Control Panel? I'll be darned if I can ever find any way to do that...am I blind or what?
  9. Fred Weiss
    20,920
    544
    113
    Sep 11, 2003
    Olympia, WA
    With fonts to be deleted selected: Control Panel > Fonts > File > Delete
  10. 2972renfro
    2972renfro Member
    286
    I think WinXP is picky about fonts too. Some free fonts don't load properly - especially postscript. The same fonts work fine on win98 machines but not on xp
  11. Dave Drane
    2,540
    1
    Ian, I do have "The Font Thing" installed and I am able to use the said font in Vinyl Master Pro and it is resident in windows. The font is also part of a package and all the others work well, but unfortunately this one is one I like and use often. When I go to favorite fonts in signlab it is there and when I click on it, it says "unable to install xxxx"
    I may have to do a reset and re-install.
    Thank you Fred for taking the time to look at it as I know you don't even have time to sleep.:tongue:
