Front lit illuminated Pole Sign price?
TXFB.INS
looking to see how our prices are for the following project.
  • Dibond 48 x 96 full color, cast Print & Lam
  • 2 sided with a hidden frame
  • 288" h
  • 5" SCH 40 uprights A36 Steel Plate base and 1-1/2 X 1-1/2 X 11 GA Square Tube for frame
  • Welded & Painted
  • concrete column shoes - 16 x 52
  • location is about 1.5 hrs one way
  • customer supplying lighting
Sign - $700
Frame - $2900
Installation - $3375
Most of that sounds quite doable, but the cost of the 2 signs looks as if you might only have it listed for one side. $700 sounds cheap for one. Probably closer to about $875 each side. Heck, your cost for the oversize diebond is a 1/3 of that cost, plus vinyl, ink, laminate and apply it all.
TXFB.INS
thanks,
and regarding the dibond I miss read the specs the initial size was 60 x 120 but was changed to 48 x 96 because of the price
so the 700 is for 2 48x96 panels
thanks,
We'd still be about $1,100 for the two.
Not to be smart, but I'll bet if this person on private land wanted to put an addition on his house or run a new service to his house, he'd hafta get all kindsa permits. You even need to know what's under ground before you start digging that low.... anyway, around here, you must.
